Hi
I have a M2TS (AC3 filter for 5.1 channel audio) Blu Ray Rip which is compatible with a ps3, but I am trying to figure out how to convert this file to play on my xbox while maintaining video quality and the 5.1 channel audio WITHOUT using tversity.
Any help/advice would be greatly appreciated, Thanks!
Please wait a few days before bumping your own thread.
Moderator redwudz -
I haven't got an Xbox, but these links from google look relevant:
http://forum.teamxbox.com/showthread.php?t=481103
http://www.infobarrel.com/Supported_Video_Formats_for_Streaming_to_Xbox_360
http://gizmodo.com/5096103/a-complete-guide-to-playing-video-files-on-your-ps3-xbox-360-or-wii
Some questions:
Why can't you use tversity? Have you sucessfully played videos on your Xbox 360 before; if yes, what format were they? Have you got a video encoder on your computer? -
The user may not want to use tversity because they may only have a wireless network and that is not ideal for video.
For best results use wmv or divx for the xbox. You'll need to encode to 5.1 wma audio for wmv. You can use ac3 or dts Standard definition audio for divx on the xbox. I think the xbox should be able to handle 720p or 1080p divx but I have never tried. I do know it does handle 720p wmv just fine.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Problem Converting from MKV to M2TS
By eleusis211 in forum Video ConversionReplies: 5Last Post: 31st Mar 2012, 21:13 -
Help converting m2ts to mkv
By Legiit in forum Video ConversionReplies: 5Last Post: 28th Dec 2010, 20:03 -
need some help converting m2ts files
By huntsman in forum Video ConversionReplies: 9Last Post: 23rd Apr 2010, 18:44 -
Converting M2TS video
By storebatfar in forum Video ConversionReplies: 1Last Post: 22nd May 2009, 18:39 -
Video file time length is incorrect after converting to M2TS
By Alterego in forum Video ConversionReplies: 0Last Post: 18th Oct 2008, 10:54
