Hi, I have an avi file which, when I open it in the KMPlayer, covers only part of the screen - there are two-inch black bars on every side of the picture. Now, this is easy to correct in the KMPlayer but I would like to convert this avi to DVD and wonder how it will look then. I don't have a DVD so I can't try it and see.
What should I do? Below is the Media Info output from the KMPlayer.
Thankful for any help,
Goran
E:\Färdiga torrents\Korta\Bombi Bitt och Jag (TV 1968)\Bombi Bitt och jag 1968 1 av 4.avi
General
Complete name : E:\Färdiga torrents\Korta\Bombi Bitt och Jag (TV 1968)\Bombi Bitt och jag 1968 1 av 4.avi
Format : AVI
File size : 774 MiB
Duration : 49mn 11s
Overall bit rate : 2 200 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2542/release)
Writing library : VirtualDubMod build 2542/release
Video #0
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 49mn 11s
Bit rate : 1 998 Kbps
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.135
Stream size : 703 MiB (91%)
Writing library : XviD 1.2.0SMP (UTC 2006-01-08)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 49mn 11s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 67.6 MiB (9%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Writing library : LAME3.98.4ªªªªªªªv%À
Ignorance more frequently begets confidence than does knowledge.
Just crop it when you convert to dvd format. Use for example avstodvd(free) or convertxtodvd.
Thanks Baldrick and Soixante! What a great site this is - always quick, informed answers to whatever questions you might have and no condescending attitudes toward us n00bs.
Love it
♀&♂Ignorance more frequently begets confidence than does knowledge.
Output to DV instead of dual screen, import to another PC
By caseylite in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Jan 2009, 09:10 -
screen capture output to dv stream
By bissquitt in forum Video Streaming DownloadingReplies: 12Last Post: 27th Jun 2008, 03:22 -
AVI split/screen output
By cinnamontea in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2008, 22:08 -
Resizing to Fit TV Screen
By bolson1 in forum EditingReplies: 2Last Post: 12th Feb 2008, 21:49 -
Progressive resizing from quarter pip to full screen
By hugo machefer in forum EditingReplies: 1Last Post: 17th May 2007, 10:21
