I have a standard def camcorder (Canon GL2). I need to record straight from that into a DVD recorder using DVD-R media. My old DVD recorder just gave out. I purchased a Panasonic DMR-XW380 which is HD. Will this work? I don't have much experience in these matters - the guy at the shop said you can only get HD recorders now and I forgot to mention my standard def camera.
Form what I see in the product specs about that particular unit, the HD part is for the DVR (recordings made to hard drive). Thus, I think DVD part would be standard definition.
Another issue: you list your location as US, and NTSC country, but it seems this unit is sold in PAL countries. -
Jmin - welcome to the forums. You should not say "HD DVD" as that refers to a dead format for HD video and there is no longer any support for it.
DVD format does not in any way support high definition. I'm not aware of any BluRay recorders sold in the USA, but if such things do exist I'd bet that you're not going to like the price (thousands of dollars). Just because a "guy at the shop" says something that doesn't mean it's true. -
Panasonic makes what they call a Freeview HD recorder made for the UK which can at times be bought here on ebay and possibly other places. The ONLY HD recording it does is from Freeview which isn't available here. It will not record external HD sources.
I believe those recorders are multi-system, not sure on that though, if it is then it will work. -
Of course its multi system, PAL is standard in the UK!
*** Now that you have read me, do some other things. *** -
The DMR-XW380 has two Freeview HD tuners and a 250GB hard disk, enabling recordings to be made that can then be archived to DVD. Around 255 hours of standard definition recordings can be made, or roughly 65 hours of HD programming, though the latter can't be archived to a DVD in hi-def, of course.
Read more: http://www.techradar.com/reviews/audio-visual/digital-tv-recorders/panasonic-dmr-xw380...#ixzz155dulZ6X
Upscaling Standard definition videos with software
By TheOncomingStorm in forum User guidesReplies: 4Last Post: 30th Apr 2012, 13:32 -
Does Bluray support standard definition bitrates above DVD Maximum?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 16Last Post: 14th Feb 2012, 17:27 -
Converting Standard Definition into HD
By Austehn in forum Video ConversionReplies: 1Last Post: 22nd Oct 2008, 20:03 -
Can't stretch this video from Sony DVD camcorder (standard definition)
By edong in forum Authoring (DVD)Replies: 2Last Post: 16th Oct 2007, 12:47 -
Mistake to buy a standard definition TV?
By LT9000 in forum Newbie / General discussionsReplies: 39Last Post: 28th Aug 2007, 10:39
