Hi
I use RipBot mostly just to not waste space on my drive and convert most of my TV series and some movies to MKV in my spare time.
I just updated to 1.16.3 and find its all while q is being processed ability a great help.
Strange thing though is its now doing the some level of work, a little bit slower yet using only 3% of my cpu, not even enough to register for my load level OC which would probably keep it to its old time.
With 1.16.2 it used to use 97% of my CPU so this is essentially a great improvement, yet would it be possible to get it to use more than 3% of my quad core, stands to reason if it can do a 40min episode in 11 minutes while only using 3% of my cpu then it should be to complete the task in a fraction of the time if i could increase its CPU usage.
Using the same high quality settings as i was with the older version.
Results 1 to 1 of 1
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 01:41 -
decrease file size
By zsuppguy in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2010, 16:30 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 17:32 -
Removing a running time from vhs conversion
By eiffelgirl in forum EditingReplies: 10Last Post: 4th Dec 2008, 00:41 -
Decrease size of dvd
By haris in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 12:58
