  1. I was trying to use Flaskmpeg and CCE. When i went to option on flaskmpeg the CCE option was not there. Is there a certain version I have to run in order to get that option choice. I have followed the Flaskmpeg How to on this page. And again my flaskmpeg does not have this option. If anybody can help please feel free to respond. Is there any other program I can use to run CCE through.
  2. You need to have the CCE premiere plugin in the FlaskMpeg directory, renamed from the original to cinemcraft.cm.flask. You get the plugin by downloading one of the trial versions of CCE available at the cinemcraft website (wwwcinemcraft.com). For the option to install the plugin along with CCE trial you need to have Adobe Premiere 5+ installed on your system or there is a patch at www.doom9.org on the download page. Use the MS-DOS prompt to rename the plugin. BTW Doom9.org also have a trial version of CCE (CCE SP 2.5) that includes the plugin on the software page.
