Hi all,
I have a VHS video of the family. The audio is out of sync when people are speaking, the lips are about 1 second behind. Can someone please advise on which TBC can fix this problem. I am wanting the footage to go onto DVD.
Actually as an afterthought, can a TBC fix the audio and record it straight onto DVD?
Thank You
josel
Most consumer TBC's lack any audio processing. Better to fix audio sync in an editor after computer capture.
In pro live broadcast environments a separate audio delay unit is used to correct for video path delays but I doubt you are prepared to spend thousands.
PS: I see in Google that there are consumer level audio delay units out there now including the Data VideoAD-100 ($422).
http://www.bhphotovideo.com/c/product/621077-REG/Datavideo_AD_100_AD_100_Audio_Delay_Box.htmlLast edited by edDV; 10th Nov 2010 at 00:23.
http://www.kiva.org/about -
Sorry did not make myself clear. When I have the DV tape playing on my camcorder the lip sync is fine. But when I try to put the footage from the camcorder via premiere pro onto the PC then the audio sync is fine for the 1st 30 minutes, then for the last 20 minutes goes out of sync.
This is not an issue that can be remedied with a TBC. Let's go back and find out 2 things: 1) How are you getting the footage from camcorder into the computer. A firewire interface? 2) You said you are using Premiere to capture, but what is the project preset you are using (including both video and audio codecs and settings)?
More fundamentally, is the original VHS or DV?
If VHS, is it going via DV? If so, how?
Cheers,
David.
Time Base correctors
By Spektre in forum Capturing and VCRReplies: 8Last Post: 22nd Aug 2011, 22:50 -
Time Base Corrector Information
By Sprout in forum Video ConversionReplies: 4Last Post: 11th Apr 2010, 03:33 -
Do I need a Time Base Corrector? If so, which do I get?
By Smack2k in forum Capturing and VCRReplies: 3Last Post: 11th Jul 2008, 10:41 -
Anyone try the TV One 1T-TBC time base corrector yet?
By heman31 in forum RestorationReplies: 0Last Post: 15th Sep 2007, 17:20 -
Video as Home Base Bussiness???
By A_51 in forum Off topicReplies: 44Last Post: 3rd Jul 2007, 12:24
