So I got the blackmagic intensity pro, I had it working about a month ago, then I took my xbox off the link for a LAN, brought it back, now it doesn't work!
I did have it working, so I know it has to be put on 1080i, and the control panel settings and media express settings. I upgraded my drivers to 3.9.1 and still nothing,
can anyone help? :c
edit: Totally forgot to add this, in media express it's just blank, nothing at all, no audio, no video
Results 1 to 12 of 12
https://forum.videohelp.com/search.php?searchid=89189
That damn super secret impossible to find search function!!!!
LOL!!! -
"Sorry - no matches. Please try some different terms."
it helped so much :O -
That's funny... because the link in my post, which was basically just a search with these two terms in it, "blackmagic intensity" & "360" brought up 47 hits....
See the funny looking writing in red, it looks like this,
Click on it..... -
are you sure you're being condescending enough? I just said it came up with no hits when I clicked it... But now I know what you searched I'll try that. (Just FYI, I've done it already, didn't help)
Double check all your connections. Make sure you didn't swap the in/out on the BMIP.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Have a good one,
neomaine
I've been having the same problems, but I just installed the BMIP yesterday. From my endless searches, it seems that many of the problems are random and unique w/o any real resolutions. I'm going to continue the search and post back if I find anything.
I've been back and forth with BM support all day (they are really good, btw), but nothing has helped.
It's funny how something that looked so simple is proving a pain.
1.XBOX HDMI out > BMIP HDMI in
2. BMCP input settings of HDMI Video & HDMI Audio.
3. Media Express capture settings of HD 720p 59.94 (even tried others).
It was supposed to be as easy as that! This could prove to be a pretty expensive paperweight. -
InfamousDX,
Not that this will fix your problem. But, I hope you have an HDMI splitter in your config. You will NOT be happy with the lag you will get if playing from the ME window. Preferred config:
- 360 (720p) > splitter
- splitter > monitor/tv
- splitter > BMIP in (720p/60)
You shouldn't need anything int he BMIP out. Make sure you have the the IN and OUT ports correct. If I remember right, they weren't labelled on the card itself. I had to look at a picture in the user manual.
I think you have to turn on your 360 first. For some reason I remember a sync issue and turning one on before the other. Might be HDCP related, don't know.Have a good one,
neomaine
Thanks for the tip. I already found that out through some research so I have an HDMI splitter coming. As of right now, still hoping to just figure out the darn 360 > BMIP input.
I tried a few things that customer service suggested like hooking up my Wii and SD DVD player. Tried both, changed settings accordingly and I get nothing on the Media Express preview screen. For the Wii, actually, the preview screen was black but the sound bars were jumping so I knew it was picking up sound. And then when I captured and played back, it did capture the sound of the Wii menu background sounds. Aside from that, I haven't gotten any closer to getting the BMIP to work with my 360.
Blackmagic Intensity Pro - Xbox 360 to PC capture audio issues
By xmadmardiganx in forum Capturing and VCRReplies: 71Last Post: 22nd May 2011, 18:28 -
Help capturing from Xbox 360 with Blackmagic Intensity Pro
By SkinnyRabbit in forum Capturing and VCRReplies: 10Last Post: 1st Oct 2010, 10:44 -
Blackmagic Intensity Pro + Xbox 360 Hookup Question
By xmadmardiganx in forum Capturing and VCRReplies: 6Last Post: 15th May 2009, 17:52 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum Capturing and VCRReplies: 0Last Post: 22nd Apr 2009, 15:27 -
blackmagic intensity / Xbox 360 / Adobe premiere pro CS 3
By jonakangou in forum Capturing and VCRReplies: 11Last Post: 17th Jul 2008, 00:42
