Results 1 to 27 of 27
  1. I Build DVD NTSC+PAL SYSTEM 720x576 30fps >60fps De-interlance Mode +Upscaling Filter Build in DVD
    http://hulashare.com/viewer.php?file=24394375893491606148.jpg
    Sample Video
    DVD Format 720x576
    24fps
    Quality than HD720p ,1080p
    http://www.mediafire.com/?35mcxe1b9pw02lz
    I can build dvd to 720x576 23.976fps, 29.97fps, 30fps to DVD Standard Disc(IFO,BUP,VOB) with my VC++ programs.
    Can play dvd player.
  2. haha. weirdest spam i've seen in a while.
  3. 720x576 at 24 fps is not DVD compliant.
  4. Originally Posted by packetnarok View Post
    ...I can build dvd to 720x576 23.976fps, 29.97fps, 30fps to DVD Standard Disc(IFO,BUP,VOB) with my VC++ programs. Can play dvd player...
    Nice achievement!
    Even better results can be achieved with Free Tools available here on Video Help when source video is BD or BDRiP and destination is dual layer, i mean higher video bit-rate closer to upper limit of 9800 kbps. It's nothing unusual,
  5. HCenc author
    Dec 2006
    Netherlands
    The video is encoded by TMPGenc, next time make sure the GOP length is DVD compliant, it's now over 60.
    And at bitrates > 9000 most encodes look OK.
    ?? Could you please explain what your programs do ??
  6. @hank 315
    it's about HcEnc 025... it's Free and the best... nothing to worry much about.
    Hank315,
    Could you please re-check sub-routines for progressive and interlaced, i guess it's some what mixed-up.
    1) Settings 1 ---> Interlacing Option ---> (@) Progressive
    Chroma Sampling ---> (@) Progressive
    must disable all interlacing options and should not generate output with following headers tags,
    Scan type : Progressive
    Scan order : Bottom Field First
    Check your PM too!
    Software in the question above, might be triggering TMPGenc with it's own filter and pre-setted parameters.
  7. As I understand it the top_field_first flag is part of a binary structure with fixed field definitions. So it is always present, a single bit, and must have have the value 0 or 1.
  8. Rip From HD720p
    Tool
    I use TMPGEnc RIP 720p>MPEG2 is easy to use and quality but HcEnc is the best tool.
    Final Cut (Upscale Picture and Make DVD video) i think Best Quality
    My vc++ programs (Build DVD Disc with Hex FPS)
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    But it isn't a DVD Video disc. At best it falls into that weird category that KVCD's created - the non-standard, non-compliant, maybe works for some but isn't really that great anyway category.
    I don't understand what Final Cut does for the process, and there seems to be un-necessary re-encoding along the way. Yes, the image is nice, but then given a good source,a high bitrate and good encoding, it should be. However when viewed on a Full HD screen against the original 1080 source, it isn't as good.
    Ultimately though, what you have created is not a compliant DVD Video structure, and will not play correctly in most DVD players. It is therefore of limited value beyond your own intellectual curiosity.
    Read my blog here.
  10. Today i can convert 24p to 30p Progressive Non-DropFrame and Ghost Picture with my vc program
    And Upscaling To 1080p
    Can play all dvd player
    Media info
    720x480
    30fps Progressive (Non-Dropframe)
    Bitrate 9400
    Not use Megui+Avisynth
    Megui + Avisynth (ghost and drop frame)
    Tomorrow i upload show you
  11. Quality than 1080p
    30p Playback
    Motionflow (Low)
    Upscale
    Can play all DVD Player
    http://www.mediafire.com/?0d5y62itwxb8iwt
  12. Well, I got the Avatar one from the second link. It plays but that's about all I can say for it. It was incompetently done, both the frame interpolation as well as the encoding. There's something like 4 blended frames in every 6, about like what you'd get using ConvertFPS in AviSynth. It's blocky with lots of mosquito noise and a very high average quant. Admittedly the scene is a hard one to encode, but if it were left at the original framerate the results would have been much better. And there were other screwy or less than optimal settings as well.
    I burned it to a CD and played it as a Mini-DVD in my Oppo player. The video plays OK but the audio is all stuttery. I've played Mini-DVDs OK before, so I don't quite know what the problem is with this one (unless it's the non-standard framerate). I don't have DVD-RWs, and didn't feel like wasting a DVD+R on it to see how it would play in it. Maybe it would play normally but someone else will have to test. It's an interesting intellectual exercise but it looks lousy as a DVD, and can't begin to be compared to a Hi-Def video, as claimed.
  13. Video Restorer lordsmurf's Avatar
    But the bigger question is this: WHY?
    I could collect dog crap in a bucket ...
    I could eat lettuce with grape jelly and mustard ...
    I could drive my car backward in circles for a few hours in the back yard ...
    ... but why?
    Usually when you do something, there should be an obvious goal.
    Otherwise you're just a nut.
  14. I got the Stormrider one now. It looks to me like it was overly sharpened. Also, the Brightness and Contrast are no good. No decent retail DVD would use those kinds of settings (although I've seen plenty). But the blacks are crushed and the whites are blown out. It looks to me like it was done intentionally. If so, before messing around making non-spec DVDs (and as lordsmurf asks above, 'Why?') you should first learn how to prepare and encode video properly.
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    I made shorter sample,
  16. HCenc author
    Dec 2006
    Netherlands
    @packetnarok
    Just out of curiosity, what encoder did you use to create the Avatar stream?
  17. Originally Posted by packetnarok View Post
    Quality than 1080p
    30p Playback
    Motionflow (Low)
    Upscale
    I agree with manono. Terrible blending, over sharpening halos, macroblocking -- painful to watch. At least the GOP size is ok this time.
  18. Today I make news Clip
    New clip is quality than old 30%
    I use Final Cut Pro to
    Rip HD1080p to DVD Format
    Upscale
    30p
    and i use my vc program build dvd ntsc 30p
  19. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Upscale
    30p
    What do you mean by "Upscale" ?
    If your source is 1080p BD and your target is SD DVD, where do you upscale ? Why would you upscale ?
    Read my blog here.
  20. I think he's saying he's "upscaling" from 24 fps to 30 fps.
  21. regular dvd players only recognize standard video dvd format Well, I know standard video dvd format can suppoty 720*480,720*576, some new dvd players can play HD video, like HD divx/xvid avi file,
  22. Today I encoder Resident Evil Afterlife 24p to 50p
    Very Smooth
    Very Quality
    Little Ghost
    How to open My New DVD (PAL200Hz system build in)
    1. Quality 100% Smooth 100%
    Play with DVD Player (PAL Mode) + CRT Flat TV
    2. Quality 90% Smooth 100%
    Play with DVD Player (PAL Mode) + LCD TV, LED TV, Plasma TV
    3. Quality 80% Smooth 90%
    Play with Computer : PowerDVD 9 or 10 >Option>Use Hardware Acceleration and Profile Original
    4. Quality 70% Smooth 85%
    Play with Computer : VLC >Video>Deinterlance>Linear
    5. Quality 50% Smooth 30%
    Play with DVD Player in NTSC Mode
    Play with Computer : Other programs
    Download Link (DVD TEST DISC)
    Uploading Sample Clip
    HJSplit http://www.mediafire.com/?b3w2gkwrzojgr8g
    VLC Mod For PAL200Hz http://www.mediafire.com/?hk7s8nwx3rbv37n
  23. I'm a MEGA Super Moderator Baldrick's Avatar
    Please only post samples. NO FULL DOWNLOAD. It's warez.
  24. packetnarok.blog.com
  25. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Now it is spam
    Read my blog here.
  26. not spam ,you try
  27. I'm not going to download that much material just to see how badly you've messed up the movies this time.
