hi
i have animation shop 3 and i cant save AVI file animations
whne i go to save it as avi, no avi compressors show up, i can only choose uncompressed, but when i choose that it says "error writing to file"
i do have space free so thats not the problem
i can save avi files fine with premiere or virtualdub or any other video editing program. just not animation shop
does anyone know how to fix this?
thanx
Results 1 to 10 of 10
Are you running FAT32 or NTFS file system? FAT32 has a file size limit of 4GB, and that might be a problem (if your files exceed 4GB).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Using defaults:Originally Posted by Phat J
Click "SAVE AS" and select AVI for the file type, type a name to save.
Create new > Next
24 Bit > next
This next section lets you chose the codec you want, I selected DivX
, also tried uncompressed
Next, 10 frames per second > next
Next, finish
Done -
MirrorImage:
my animation is only 5 seconds long so it wouldnt be anywhere close to 4gb
plus i dont have 4gb free on my harddrive haha
letmeinforgodsake:
thats what i do, no compressors show up in the drop down list except uncompressed, and if i choose that, it says "error creating file" or something similar -
I think you have a bad installation of PSP, are you using a hacked version ?
sounds like.
Try downloading the evaluation program and install it "as is" see if it works ok before you mess around with it
7.04 upgrade is also there.
A 5 second gif will make a very tiny AVI !
email it to me, Ill convert it and send it back
ok thanx i will try that
yah its a hacked version but it worked fine b4
haha the animation is 704x480 with millions of colors so it will look really bad if i save to gif :P -
i downloaded the animation shop 3.04 trial version, but i still have the same problem :P
i emailed the company maybe they can help
do u have any more ideas?
thanx again -
Did you un-install the hacked version first and delete any traces of it in both the registry and your hard drive ?
Sometimes things get left behind, settings.. ini... reg... they can all mess up a new installation.
Maybe the hacked version works like the demo, neither will have the ability to export until you pay !. I've never seen this problem before. -
yah i uninstalled the hacked version b4 installing the demo
the stupid thing is that everything worked perfectly when i originally installed the hacked version :P
how would i know what to delete from the registry?
oh maybe i should mention i have another program that i cant use the codecs in either, Xara3D, its the exact same problem as Animation Shop, no codecs show up and i cant save uncompressed AVI
but every other program i have (Premiere, VirtualDub, TMPGEnc, etc) saving AVI works fine -
Hi
Well I would not recommend you manually deleting things in your registry, unless you know what your doing. I would be more inclined to use a registry cleaner like Norton utilities system check.
It sounds like your system is crying out for Norton
I use it regular and every time I run it, there are errors...
Not used Xara3D for sometime, don't have it installed, so cannot comment on its settings. Have you run the Paint Shop Pro 7.04 update ? maybe that would fix some problems, although I don't think it will work on a hacked version. I have animation workshop 3.04, from its updates.
Can you load an AVI in ok ?
Why does Audacity always save audio files differently?
By sldvd in forum AudioReplies: 15Last Post: 22nd Nov 2010, 15:17 -
Edit VOB files and save to dvd
By NickyJ in forum Newbie / General discussionsReplies: 9Last Post: 1st Jul 2008, 13:59 -
Best format to save AVI files on PC
By bpatters69 in forum Video ConversionReplies: 6Last Post: 31st Mar 2008, 09:31 -
Noob: How do I save these flash files to my HDD?
By peggypwr1 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 19:02 -
PROBLEM: Animation Shop Won't Export To Paint Shop Pro 8
By Aaron1927 in forum EditingReplies: 1Last Post: 10th Jul 2007, 10:44
