Hi guys,
My basic question is this. I want to run an HDMI cable out of my DirecTV tuner box into a tv tuner card in my pc. I have 2 23" LG monitors side by side and while im doing something on one monitor I want to display the feed onto the other monitor. Is this possible and if so which tv tuner card for my pc is recommended. Thank You.
There are no TV tuner cards that have an HDMI input. I have seen three video capture cards that do have one, but they will not record or display video from a source with HDCP. Unfortunately, the output from your DirecTV receiver will have HDCP.
If up to 1080i is acceptable, the Hauppauge HD PVR, an external USB capture device which uses analog component video is a better choice.
I think watching video on one monitor while working on the other is possible using Theater Mode for the video display monitor, but I have not done it myself. (Theater Mode is what ATI calls it, not sure what Nvidia calls their version of this feature.) -
If your LG monitor supports HDCP, you can set the DirecTV box to 720p/60 and connect with HDMI to DVI-D cable.
http://www.kiva.org/about
connecting my hp computer monitor as a TV
By questionsquestions in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2011, 11:03 -
What do you use as your primary computer monitor?
By johns0 in forum PollsReplies: 10Last Post: 17th Feb 2010, 22:07 -
DirecTV DVR: how do I get to my computer to record to DVD?
By hyphenate in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Dec 2009, 09:54 -
Transferring from a DirecTV DVR to Computer?
By Hangrumps in forum Capturing and VCRReplies: 0Last Post: 19th Dec 2008, 12:26 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06
