Facts about me:
- Newbie in DVD Ripping.
- Mac user.
- Also have access to Windows XP. Last resort though.
I already have a software to rip DVD's and get VIDEO_TS output folders.
I'm looking for a software to convert the "movie only" from the VIDEO_TS folders into .avi video file and .srt subtitles file.
Is this conversion I want possible with lossless quality?
If lossless quality is out of the question what software can provide the least quality loss possible?
If the output file after the conversion is large in size I don't care.
I only want to achieve the best quality possible.
Also between .avi, .mp4, .mov and all the rest video types, which one of all is the best for quality?
Thanks in-advance.![]()
D-Vision v3 or v4 is good for conversions to AVI. So are Visual Hub, its replacement(s), ffmpegX, MPEG Streamclip and a few others.
Converted video is different from its source, therefore there is quality loss. The quality of a conversion is mostly determined by bitrate in combination with a specific codec, regardless of which software you use.Originally Posted by itsjamesd
Then keep the VIDEO_TS folder. 100% quality.Originally Posted by itsjamesd
H.264 MP4 is about as good as it gets. HandBrake can let you make such a conversion with ease.Originally Posted by itsjamesd -
All of that software mentioned above is Mac compatible, right?Originally Posted by Case
If it is I guess I'm going to give a try to D-Vision, since you mentioned it first.
So, if I understand correctly, from a certain VIDEO_TS folder, the outcome conversions to .avi will always be the same regardless of the software I use?Originally Posted by Case
Might be a silly question, but that's how I got it. :/
In order to use HandBrake will I need the software that converts VIDEO_TS to .avi too?Originally Posted by Case
As in, firstly convert VIDEO_TS to .avi and then use HandBrake to convert the .avi I got to H.264 .mp4 or I simply use HandBrake to convert the original VIDEO_TS folder to H.264 .mp4 without bothering with the .avi software at all?
Thanks for the help, you were extremely helpful.
Yes.
Many software packages can convert to both high quality large files and lesser quality small files with higher compression. The quality is in the settings, not in your software package of choice.Originally Posted by itsjamesd
HandBrake will happily convert from VIDEO_TS. No need to go to AVI first.Originally Posted by itsjamesd
ffmpegX & video_ts conversion, or lack thereof
By riegal in forum Video ConversionReplies: 0Last Post: 14th Oct 2009, 05:56 -
video_ts conversion to import to imovie8
By Lu-min Chew in forum MacReplies: 5Last Post: 7th Mar 2009, 09:33 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 19:40 -
Audio very low after VIDEO_TS -> DivX conversion
By mistafro in forum ffmpegX general discussionReplies: 7Last Post: 28th Feb 2008, 18:42 -
VIDEO_TS (852x480) -> MPEG conversion: Aspect Ratio?
By jswayze in forum ffmpegX general discussionReplies: 7Last Post: 10th Jun 2007, 09:12
