Hello,
I have a LG GSA-H62L SATA DVD+RW on a Windows XP Pro SP 3 computer that cannot read a DVD+RW disc. The disc was burnt on another friend's Windows 7 computer. I've confirmed that the disc can be read on other computers that are running Vista and 7. FYI the contents on the disc are pictures and RAW files.
So far I've tried updating Nero 7, Microsoft Fix It from here http://support.microsoft.com/gp/cd_dvd_drive_problems
Tried using the hotfix from this KB article http://support.microsoft.com/kb/818733
However when I try to use the hotfix they sent me, I get the error message: xpsp1hfm.exe is not a valid win32
Anyone have suggestions?
I have a lg burner that can't read dvdrw that my other burners can read so its just the burner itself that's the problem,burners are so cheap now a days its just easier to replace it and welcome to the forums.
Also look into Adaptec ASPI drivers. I remember having that problem YEARS ago but I still think it was on XP.
Is there any chance that the disc was burned as a UDF 2.50 or higher format disc? XP cannot read these discs and you must install special software like this to do so - UDFreader
The Microsoft hot fix page suggests a solution for discs made on video recorders not PCs.
It could also be that disc was not finalized, the discs is bad, or your drive doesn't like the media (it's probably low grade crap media). It's simple enough to load UDFreader to just to see if that fixes your problem or not. -
I suspect you booktyped the DVD+RW to DVD-ROM with the other burner, which makes it absolutely incompatible to some drives.....................
*** Now that you have read me, do some other things. *** -
Why don't you try your drive, with this disc, on your friend's computer?
It's work, but it will be effective to single out the problem, which either way, is more solvable if you know what it is.I hate VHS. I always did.
I have a DVD-R that I burned 1200 songs on, my DVD player only can read 600
By frieday in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2010, 04:31 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 10:22 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
