From a newbie:
Is it possible to burn a file in TS format to a DVD (not a BD-R) so that I can play it in my Blu-Ray player? I want to maintain the hi-rez file and not re-encode it to DVD standards.
The user could make an AVCHD disc or a BluRay format disc using one of several tools, but it's impossible to guarantee that such a disc will definitely play on any random BluRay player. Whoever wants to know will simply have to try until they find something that works. I've learned with my Momitsu BluRay player that while it doesn't matter if I create an AVCHD or BluRay format disc, multiAVCHD can't produce anything under any settings that my player can play, so I have to use tsmuxer. I have also learned that while 1080i/p discs play fine in my player, 720p has so many problems that those discs are unwatchable.
issues playing burned DVD's on sony blu ray player bdp-s300
By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 15:12 -
Playing blu ray on my computer from a player
By Dankriss in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2010, 10:56 -
mkv to m2ts playing on my blu-ray player
By PSS2 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2010, 16:24 -
Burning M2TS 4gb file to play on Blu-ray player
By PSS2 in forum Authoring (Blu-ray)Replies: 5Last Post: 6th Jan 2010, 23:44 -
Blu-ray player playing off Colors
By jbandy1 in forum Software PlayingReplies: 5Last Post: 27th Aug 2009, 11:45
