hi downloaded a avi went to virtual dub thenopened file audio full processing mode then compression select no compression then conversion select 44100hz then file save wave do i have to type in here 800mb which is what ive been doing.
then opened tmpg enc oponed file selected 800mb wave for audio then load template vcd pal then select settings video source non interlace.
field bottom first.
4.3 625 pal. arrange method full screen. pixels below this say 352x288.
trhen press ok then start when i play movie back on dvd it seems to be ok but in slow motion just a bit. i know ive made loads of mistakes here so if some 1 could give me a basic rundown of virtual and tmpg enc id b very greatful thanks chelly il get there in the end.
Results 1 to 1 of 1
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 19:23 -
Help with Mac The Ripper Plz!!!
By ILoveMovies12345 in forum MacReplies: 2Last Post: 24th Apr 2009, 11:08 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52 -
my PC stats plz help can i edit on this
By Kigi in forum ComputerReplies: 8Last Post: 30th May 2007, 02:30
