Hi There
I have been looking for a forum that specialises in films/dvd/conversion so I hope I have gone to correct forum.
Basically, although a relatively experience pc user, I find this sector confusing.
I have been given some films on a memory stick and apart from other format details (which I can provide) they are all AVI.
I can of course play them on my Toshiba laptop, but want to learn the correct and simple way to convert to the correct format to play on my Sony tv/Sony dvd player.
I have XP/SP3 and the progs I have are
wmp 10
Nero OEM
Toshiba Sonic "Record Now"
Prism Video File Converter
DVD Flick
I will attach the list of films concerned showing the AVI format, and you will see that I have converted some to WMV and the odd one to MP4.
I would appreciate any help available and as simple as possible.
I think the main help would be, if I am given same again off pal and they are AVI, what format should I use to enable them to be shown on my, or my sons dvd player attached to tv.
Closed Thread
Jababo
Thanks for reply, as posted, I already have DVDFlick so I could have/and have looked at that myself, I was hoping for a bit of 1 to 1 off an experienced member
DVDFlick is the only program worth a damn on your list. I'd stick with that one.
You won't/shouldn't get any help here for pirated movies.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
film to dvd conversion
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2010, 19:08 -
8mm old film conversion suggestions
By ranchhand in forum Newbie / General discussionsReplies: 2Last Post: 5th Sep 2009, 08:05 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
film conversion problems
By hobo20212 in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2007, 08:52
