I am capturing some SD video and I want to place it on a DVD, but I believe I am adding too many steps when capturing the audio.
Here is my video workflow
Capture SD Video with VirtualDub (720x480,YUY2,Lagarath/PCM 48000/16bit)-> Edit Video with VirtualDub (I used Fast Recompress to avoid any conversions) -> Use AVISynth to convert to YV12 and frameserve to HCenc-> Final product a .m2v
To extract the audio I use virtual dub to extract the wav and then use EncWavtoAC3. Is there any way I can include the audio step into my video workflow (maybe using avisynth)
The best way to avoid compression of the video is to use direct stream copy.
The audio processing depends on what you're using to create the DVD.
A popular package, like DVD Flick, can use the WAV inside the AVI file and create the AC3 during the DVD creation.
No need to use a separate step like EncWavtoAV3.
How do you extract ac3 from m2ts when tsmuxer doesn't read the audio?
By yoda313 in forum AudioReplies: 6Last Post: 1st Jan 2011, 09:28 -
HELP for extract DTS or AC3 audio from MKV
By Riversound in forum AudioReplies: 5Last Post: 29th Jan 2010, 11:56 -
extract entire ac3/dts audio track from a DVD
By shiet in forum AudioReplies: 1Last Post: 24th Feb 2008, 03:26 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 05:56 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 15:06
