Closed Thread
    Sep 2010
    Trivandrum
    Hi Friends,
    I've got two sample torrent files of the same movie .I'm confused which one has better quality they both look much the same.i will give the tree view of the two files which Mediainfo give me .plz tell me which one to download
    First file
    General
    Format : MPEG-4
    Format_Profile : Base Media
    CodecID : isom
    FileSize/String : 14.3 MiB
    Duration/String : 56s 277ms
    OverallBitRate/String : 2 124 Kbps
    Encoded_Date : UTC 2009-12-04 13:13:47
    Tagged_Date : UTC 2009-12-04 13:13:47
    Video
    ID/String : 1
    Format : AVC
    Format_Profile : High@L4.1
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 5 frames
    CodecID : avc1
    CodecID/Info : Advanced Video Coding
    Duration/String : 56s 264ms
    BitRate_Mode/String : Variable
    BitRate/String : 1 809 Kbps
    BitRate_Maximum/String : 40.0 Mbps
    Width/String : 1 280 pixels
    Height/String : 544 pixels
    DisplayAspectRatio/String : 2.35:1
    FrameRate_Mode/String : Constant
    FrameRate/String : 23.976 fps
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bits
    ScanType/String : Progressive
    Bits-(Pixel*Frame) : 0.108
    StreamSize/String : 12.1 MiB (85%)
    Encoded_Date : UTC 2009-12-03 11:55:13
    Audio
    ID/String : 2
    Format : AAC
    Format_Version : Version 4
    Format_Profile : LC
    Format_Settings_SBR/String : No
    CodecID : 40
    BitRate/String : 307 Kbps
    BitRate_Maximum/String : 460 Kbps
    Channel(s)/String : 6 channels
    ChannelPositions : Front: L C R, Side: L R, LFE
    SamplingRate/String : 48.0 KHz
    StreamSize/String : 2.09 MiB (15%)
    Encoded_Date : UTC 2009-12-04 12:43:58
    Second File
    General
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 35.6 MiB
    Duration : 1mn 52s
    Overall bit rate : 2 643 Kbps
    Encoded date : UTC 2010-10-06 07:49:48
    Tagged date : UTC 2010-10-06 07:49:48
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 6 frames
    Format settings, GOP : M=2, N=32
    Codec ID : avc1
    Duration : 1mn 52s
    Bit rate mode : Variable
    Bit rate : 2 064 Kbps
    Maximum bit rate : 7 906 Kbps
    Width : 1 280 pixels
    Height : 528 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.127
    Stream size : 27.8 MiB (78%)
    Encoded date : UTC 2010-10-03 12:48:31
    Tagged date : UTC 2010-10-06 07:49:53
    Audio #1
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 1mn 52s
    Bit rate : 447 Kbps
    Maximum bit rate : 557 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 6.01 MiB (17%)
    Encoded date : UTC 2010-10-06 07:01:37
    Audio #2
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1mn 52s
    Bit rate : 128 Kbps
    Maximum bit rate : 179 Kbps
    Channel(s) : 2 channels
    Stream size : 1.71 MiB (5%)
    Encoded date : UTC 2010-10-06 07:02:25
    Many Thanks
    canada
    What's the name of the movie?
  3. Originally Posted by johns0 View Post
    coming from a mod isn't that likely entrapment? torrent movies aren't likely to be legal....
    Sep 2010
    Trivandrum
    Fight club
  5. too old to look up, and you don't say which release groups. download some parts of each and check them yourself and see which you prefer. no other way to say.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Fight club is only 11 years old and is illegal to download and against forum rules,please buy the movie,thread is closed.
