I am going to convert a movie of mkv format with integrated dual audio of 4.96GB to 4.38GB with 720x304, 25fps, Divx Mpeg-4 codec + dual audio ac3, 448kbps 48000Hz, 6 channels both. so that it can be able to fit into a DVD of 4.7GB. the bit rate of video would be above 3000kbps and i also want to add subtitle
so I want to ask if i convert a file and burn it on to a DVD then,
It will be a playback on a home DVD players or not???
does i will able to change audio???
does i will able to make subtitle ON or OFF??
does a player also supports format like xvid.avi, mp4, or mkv??
or i get some problem as i have read the 1st post of Baldrick here
https://forum.videohelp.com/threads/290800-My-DivX-DVD-Player-can-t-play-my-avi-DivX-xvid-video
The Philips 5990 Divx/DVD player can switch between multiple audio tracks and subs when playing Divx/Xvid AVI files. Normal DVD players don't play Divx at all.
Is there any DVD players which can play HD DivX?
By kalingga in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Jul 2011, 19:06 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 22:27 -
Do any of the current DVD players from Best Buy allow DUAL audio out?
By KillerQ in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jun 2008, 14:31 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
Any recommendations for players that will play dvdr dual layer discs?
By vinland in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Oct 2007, 04:02
