Hi All ,
I have DVB Card Tevii S420 and using ProgDVB as my DVB viewer , I record videos from channels as MPEG or TS [NOT HD at Common]
Want to know how to edit and convert those files to Avi and MKV as same as famous scene groups do liki LOL,FQM and 2HD
I care about good quality with good size and what is better to use MKV or Avi
If there any specific codecs i should use at ProgDVB to get best video it will be great to guide me
I tried to use Search but i got lost and couldn't put hand on what i want
Now using Avidemux 2.5 to convert and edit my videos
Thanks for your time and waiting your help..
I know that i will not get a "Superb" quality from Non-HD channels , all i need is the best quality i can get from the original file with good size
So you advice me to save my files as MKV instead of Avi ??
And i found TV releases 350MB is great cuz they originally encoded from HD Channels , Right ??
Also at Avidemux 2.5 i am using Crop to remove black lines from top and bottom of video and removing commercials....
Sorry for lot of question but i am new to all this ....
MPEG TS recorded from DVB: impossible to extract subs good enough for OCR
By edea in forum SubtitleReplies: 25Last Post: 25th Oct 2011, 13:07 -
Broken Mpeg-4 recorded video
By RWB713 in forum Video ConversionReplies: 1Last Post: 9th May 2011, 04:00 -
Demuxing HDTV .ts recorded in DVB-TH tuner - help
By newstrength in forum DVB / IPTVReplies: 7Last Post: 2nd Jun 2010, 14:34 -
XviD Quantization type, H.263 vs MPEG; and GMC for hand recorded material
By carlaron in forum Video ConversionReplies: 41Last Post: 2nd Mar 2010, 23:36 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 23:06
