hi! all. i haf a mkv movie file which when i play on my tv using my media player, the sound was very soft. is there
anyway to increase the volume of the audio so that i dun haf to crank up my tv's volume to over 50% to get slightly audible
sound.
Extract the audio using MKVextractGUI and then, depending on the type of audio, use an audio editor to normalise it.
Then, use MKVmerge to put the audio back into the MKV. -
Hi! i've downloaded both the software but when i open MKVextractGUI, it prompts me to install MKVmerge.exe into the same folder so i copy the MKVtoolnix.exe into the folder but still got the message. anyway to provide tutorial? i'm quite new to this MKV method
Try it this way. Install Mkvtoolnix. Then copy MkvExtractGui into the mkvtoolnix install folder.
AVI file volume increase.
By seven1970 in forum AudioReplies: 8Last Post: 31st May 2013, 17:07 -
Increase VOB file volume
By boren1969 in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2010, 23:19 -
volume increase
By natty in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2008, 11:08 -
how to increase the volume of the audio?
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 06:45 -
Trying to find a program I once had to increase volume on a audio file
By natty in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2007, 15:57
