Help...I have been copying movies now for 6 years, I have anyDVD HD 6.7.1.0., DVD Shrink and DVD Decrypter, all of a sudden now when I put the dvd in DVD HD does it's work, then when I bring DVD Shrink up and go to open files I get this message "failed to read file E:/", it's a new release (Iron Man 2)...is there any way to fix this, or is this the new technology which gives me a headache....There must be away to get around this...You guys are so intelligent I know you have an answer for me....![]()
Closed Thread
Results 1 to 13 of 13
Iron man2 should work according to anydvd changelog. Have you tried rip it to an iso with just anydvd before using dvdshrink? Right click on anydvd and choose rip to image.
Or try latest dvdfab decrypter and see how it works.
ok..trying that, but then what?....with the AnyDVD it's at 85 at the moment...then what happens when thats done...what do I do?
Thanks for your time!
hey patty i don't use dvdshrink nomore or anydvdhd but there good maybe your doing something wrong? um i ripped ironman2 also but r4 you can use dvdfabdecrypter like baldrick said then open it select dvd E:/ Select rip to Harddrive then you have a dvdfolder right ok then you should be able to do wateva you want with it as dvdfab and anydvd latest version should work with ironman 2 take care
I've used dvdfabdecryptor, but the movie has to shrink in order to fit on the disc thats why I use dvd shrink... anydvdhd the strips the code right off...omg...i dont understand....I have to take the movie back in 10 minutes...but I still have the iso in my documents, I will try later, maybe I'll delete shrink and reinstall dvdfabdecripter...
I just dont understand how it will shrink down to fit on my blank dvd, if I dont have dvd shrink
you guys are very patient with me...and i thankyou...
I may have to come back later...feel a "migrane" coming on...lol
"Failed to read video frame"
By jva1254 in forum EditingReplies: 1Last Post: 25th Sep 2009, 06:59 -
File Identification Failed CONSTANTLY
By kardashian in forum MacReplies: 0Last Post: 12th Jul 2009, 06:41 -
Avi to DvD .failed. "Cannot read .m2v ?
By ukel12 in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2008, 10:47 -
failed to read the video data from the source file (80004005)
By tertill in forum Video ConversionReplies: 3Last Post: 31st Oct 2007, 10:26 -
DVD File Allocation Failed
By Emeraldas in forum Newbie / General discussionsReplies: 8Last Post: 22nd Sep 2007, 09:26
