I have two MKV files, each of which can be independently played on my WD Live Media player, however when I join the two mkvs using MKVmergeGUI, the resulting file is unplayable on the same Media player, any idea what could be wrong here ....
Thanks in advance
Regards
Sammy
C2D 6300@3.21Ghz|Vista Ultimate x64|P5B-Dlx Wifi|Transcend 4 GB 800 Mhz|XFX 8800GT 512 MB Alpha Dog Edition|Samsung 19" 940BW|1.5 TeraByte Storage|ASUS SATA DVDRW|Altec Lansing ATP5|APC 800 Smart UPS.
Use an older version of mkvtoolnix, 3.4.0 or older should work https://www.videohelp.com/tools/MKVtoolnix/old-versions#download . See also https://www.videohelp.com/tools/MKVtoolnix#usercomments
^^ Ok will give it a shot, any idea why this older version....???
C2D 6300@3.21Ghz|Vista Ultimate x64|P5B-Dlx Wifi|Transcend 4 GB 800 Mhz|XFX 8800GT 512 MB Alpha Dog Edition|Samsung 19" 940BW|1.5 TeraByte Storage|ASUS SATA DVDRW|Altec Lansing ATP5|APC 800 Smart UPS. -
I just read the comments from https://www.videohelp.com/tools/MKVtoolnix#usercomments
The reason is header compression is enabled by default past versions 4.0.0 . Many devices require a firmware update to play.
You can either disable header compression, or use v4.0.0 or older
The newest version has an option to disable header compression by default -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Unable to play certain mkv files on Viewsonic Media Player(VMP70)
By bappida69 in forum Newbie / General discussionsReplies: 5Last Post: 18th Oct 2011, 17:40 -
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 11:29 -
how to make x264 content in mkv container play on D-Link Media Player
By roise_r in forum Video ConversionReplies: 11Last Post: 21st Mar 2009, 17:43
