  1. I'm wondering if there's a separate tool to do vob cleanup similar to what RipIt4Me does?
    I can use RipIt4Me but it won't load a VIDEO_TS folder. It's a pain to create an image file
    and mount it just to clean up the vobs. Anyone know exactly what it does or if there's
    a cleanup tool that duplicates that function?
    http://milesaheadsoftware.org/
    Fully enabled freeware for Windows PCs.
    Nov 2005
    i believe the cleanup tool in it is FIXVTS
    i do the same as u mention, create iso's and run it thru Ript4me and clean up stuff...doesnt bother me though
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yes the tool in ripit4me is fixvts.
    But you don't need to make an ISO to run through ripit4me, you just need he video_ts folder and open it in fixvtxs.
  4. I thought there was a separate app but it's been so long I couldn't remember. If I had RipIt4Me in it's own folder I guess I would have seen it but I just put it in a general purpose folder in my path. That's great. Thanks.
