Results 1 to 12 of 12
  1. hi,
    ive got some avi files on my laptop that play perfectly.
    but when i put them onto my memory stick and play it through my tv it says it's 3 seconds long but it plays the whole length, but when i burn them to a dvd-rw and play it on my dvd player they say they are only 3-4 seconds long and cut off and goes onto the next file but if i stop the RW it says file not supported but i know the file is fine and the previous episode played fine??
    this is relly gettin up my nose..
    can anyone help me??
    thanks
    Pete..
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    MUCH more info needed.
    Your TV has a USB port?
    Your DVD player plays AVI files?
    Your DVD player plays Divx/Xvid files?
    Your DVD player plays Divx/Xvid files burned to a DVD as data?
    You converted and authored those AVI files to a DVD(with a VIDEO_TS folder)?
    Were these AVI files possibly originally created outside of America?
    etc etc etc etc...
  3. yes my tv has a usb port
    yes my dvd player plays everything but mp4 files
    yes my dvd player playes avi/divx.xvid bunt to dvd/rw
    no i dont burn it as a dvd (video_ts) foler just burnt as data disc usally works fine
    no idea where the avi's were created. it is an austrailian show so highly possible..
    i think that was everything answered. lol
  4. im such a noob, i dont understand gspot?? ill upload img file so u can c what i c
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Reconvert with avirecomp.
  6. I would try a quick remux with VirtualDub first:
    1) File -> Open Video File
    2) Video -> Direct Stream Copy
    3) File -> Save as AVI
    That will only take a minute.
  7. virualdub was a no no
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Just install koepis xvid codec.
  9. i used avirecomp. and it works perfect now, thank u so much for all the help..
  10. some files do this in virdub, if click yes the audio goes out of sync, how can i get passed it?
  11. Originally Posted by turbopwr View Post
    Click NO instead. That usually works.
