Hello all you wonderful people who help us! I've been asked to solve a problem and the goal is they need a video they created burned to a movie DVD disc:
A non-profit for kids lost a hard drive and their only copy of their finished movie was on the flip video website. I managed to get the FLV down to my hard drive and it plays fine, if even at a low res. Audio is in sync. I've tried using the Windows 7 Live Movie Maker and Windows DVD maker a couple different ways and every time the audio is way out of sync. I think what I would like to do is extract from the FLV the audio and video separate and then put them back together in windows movie maker, or I might buy the vegas studio for this.
Any suggestions for me?
Thanks!
Results 1 to 9 of 9
FLV and WMV are often considered "end of the road" video formats....it's not easy making something from them once they are in either of these two horrendous formats. Sometimes you get lucky but most often you get major sync issues. Your bets bet is going to some intermediate format like uncompressed AVI first, fix the issues there...then create the terrible looking DVD once everything is synced.
Windows movie maker is NOT gonna do much good....and buying Vegas will be a waste of money.
Believe it or not I often use Super to get from FLV to something else. -
I've had some luck with DVD Flick encoding the FLV dirtectly.
Also, installing FLVSplitter and using AVStoDVD may also work. -
Hi, Thanks for trying to see what you can find. Here is the text output from mediainfo
General
Complete name : C:\Users\bob\Desktop\CAA Film Sept 2010.flv
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 132 MiB
Duration : 17mn 33s
Overall bit rate : 1 052 Kbps
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 17mn 33s
Bit rate mode : Variable
Bit rate : 1 030 Kbps
Width : 480 pixels
Height : 270 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.265
Stream size : 129 MiB (98%)
Tagged date : UTC 2010-07-15 16:18:58
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Codec ID : 40
Duration : 17mn 32s
Bit rate : 19.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 11.025 KHz
Stream size : 2.38 MiB (2%)
OK, hey, DVD Flick made a nice DVD folder with video and Audio_ts folders.
Now I just need software to right these folders to disc. I googled for this and a youtube movie said I should get nero from thepriratebay. I'm sure you guys have a better option, no?
I downloaded AVStoDVD but it looks like it wants to re-encode.
Please send your suggestions!
Thanks again!
Converting VFR FLV (H264/AAC) to AVI (other) w/o sync issue
By kwondra34 in forum Video Streaming DownloadingReplies: 43Last Post: 11th Apr 2012, 01:54 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 12:51 -
FLV to DVD - audio out of sync
By intel352 in forum Video ConversionReplies: 16Last Post: 30th Mar 2009, 15:07 -
FLV file with severe lip sync issue
By neftv in forum Video ConversionReplies: 4Last Post: 3rd Mar 2009, 16:26 -
.mov to .flv - Sync issue and shortened video.
By dillingham in forum ffmpegX general discussionReplies: 1Last Post: 4th Jun 2008, 17:15
