I have autogk encode files separate into 2 parts, 700mb each. How do I join them back into 1 file? Can it be done via autogk?
Thks.
You can't join them with AutoGK. You could have simply output a single 1.4GB file in the first place, but that horse has since bolted.
Because AutoGK has created the two parts in a single session, they should have common settings, so you should be able to join them easily in Virtualdub or AVI Demux, without the need to re-encode.Read my blog here.
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 03:08 -
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 15:37 -
ıs Xvid 1.2.2 causing undersized files in AutoGK?
By Anonymous5394 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2010, 06:19 -
Join Avi (xvid) files together
By SpyJoe in forum EditingReplies: 11Last Post: 26th Aug 2009, 18:44 -
Best program to re-encode XviD files to make them smaller?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 23:32
