I need help desperately!!! My Panasonic camera imports my videos on my pc as .cont files which no program, so far, supports. Please, please help. What do I do? I have all these videos sitting in my hard drive and I'd like to burn them to DVD. I tried using the HD writer, but, it took over 18 hours just to burn 13% of the video(s). I don't know how this all works, so please someone dumb it down for me. Thanks!!!
What model Panasonic camera?
What kind of video? High Definition?
If a device produces proprietary files, then logic says it should come with its own software for transferring. Is that this "HD Writer" app?
When you say it took over 18 hours just to burn 13% of the video(s), how much play time does that account for?
When you transfer HD video to (SD) DVD-Video, then everything needs to be converted, which is time consuming. No way around that. -
A quick google search on the single piece of useful information you supplied seems to indicate that your cont file may not actually be video.
In addition to the questions already asked, what type of computer, software, connecton to pc, etc.
You have managed to communicate that you have somehow screwed up. Failing to give specific, useful information would be your second one. Now, try identifying your camera, software, methods, all files transfered, file size data, and other basics and you might actually get a useful answer.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Are there tutorials on this forum for converting AVI to a iPhone 4 MP4 cont
By rocky12 in forum Newbie / General discussionsReplies: 2Last Post: 5th Sep 2011, 09:12 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
