Hi Guys,
Looking to tweak these settings in xmedia recode (no forum on the user site, etc....pity)
What MediaInfo says about my current encode ---> (What I'm looking for)
direct=1 ----> direct=3
chroma_qp_offset=-1 ---> chroma_qp_offset=-2
And could someone explain these ones to me (I haven't seen them in Handbrake, etc):
vbv_maxrate=10000 / vbv_bufsize=10000 / crf_max=0.0 / nal_hrd=none
For a start. say what kind of file you're trying to make.
There is a folder of .ini files, "Profile", that have the presets.
You may find what you're looking for in these.
You can copy and edit these to a custom profile.
It's a generally solid program, but it does lack any way to give feedback. I tried emailing the author about a problem a while ago, no response.
Of course, I hadn't paid him anything. -
vbv-maxrate is the maximum bitrate that can enter the buffer , vbv-bufsize is the size of the theoretical buffer, crf max places a lower limit on the quantizer (when it's set to 0, that is lossless) , nal-hrd is information required for blu-ray and some devices (HRD = hypothetical reference decoder)
I don't use xmediarecode, but in some programs you can access extra settings by using the custom commandline box (entering values manually). I think you can in handbrake. You can for sure in megui
If you want a list of most of the settings
http://mewiki.project357.com/wiki/X264_Settings -
@AlanHK: x.264/AAC
@poisondeathray: Thanks for that info and the link, it's gotten me closer to sorting these last few settings. megui....gonna test it out! xD
direct was the "B-Frame Direct Mode"
* Auto gives "direct=1"
* Temporal gives "direct=2"
* Spatial gives "direct=3"
* None gives "direct=4"
What parameters for good quality compression with Xmedia recode ?
By guiton2002 in forum Video ConversionReplies: 8Last Post: 21st Jun 2013, 19:14 -
Xmedia Recode help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 12:36 -
XMedia Recode v 2.2.1.6
By Bonie81 in forum Video ConversionReplies: 2Last Post: 4th Jun 2011, 15:19 -
Xmedia Recode V. 2.25.8
By pepegot1 in forum Video ConversionReplies: 20Last Post: 30th Aug 2010, 00:58 -
xmedia recode
By csmidha in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 05:34
