What is the proper way of connecting the VCR to DVD so i can make a copy of cd or dvd i am watching to VCRs? I tried a couple and didnt work.
All protection in my apex are turned off.
Do i connect my VCR to DVD then VCR again to tv?
Yep, but if watching a DVD you are going to have macrovision protection kick in, and you will have to have your VCR on all the time when you want to watch DVD.
I bought a cheap switch box from Radio Shack and plug everything into it and then one set of cables out to TV/Stereo. I can switch from device to device, plus it has a copy button where the signal can be sent to my VCR from any other source (need VCR with AV in and out). So I can watch DVD without having the VCR on or having macrovision kick in...and I can make copies of SVCD/VCD/and unprotected DVD to VHS by pushing the copy button.
Neat O.
Oops, didn't notice the bit about protection being turned off on your Apex. Yeah, you can just connect DVD to VCR to TV and ignore my lengthy bit above =)
Connecting a TV, cable box, and VCR/DVD
By jmarsico in forum Newbie / General discussionsReplies: 11Last Post: 31st Jul 2010, 20:31 -
Need help connecting Hauppauge 150 PVR from TV/VCR set up
By magicfingers in forum Capturing and VCRReplies: 17Last Post: 5th Sep 2008, 07:41 -
recording copy-guarded material with VCR/DVD re-writer combo?
By corneileous in forum Newbie / General discussionsReplies: 16Last Post: 21st Jan 2008, 18:56 -
Connecting/setup VCR/DVD recorder complicated
By peeaytee in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 15:00 -
Problem connecting VCR to computer
By unicorn in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2007, 00:18
