I have 1on1 copy of Blu-ray disc in HDD. How can I remove audio tracks from it?
Results 1 to 11 of 11
Use the 'Add' button under the 'Input' header. I open the largest .m2ts file in BDMV>STREAM. Use Details view in Windows and click the 'Size' header to bring it to the top. Most main movie .m2ts files are about 15 - 40GB, so easy to find. If you're not sure or if the main movie is split among several .m2ts files, use BDInfo and it will tell you the main movie .m2ts file(s) .
With tsMuxeR, you can remove the audio and subs (Presentation Graphics), then just hit 'Start Muxing' at the bottom. Leave all the other settings at default most times. It's very fast. Make sure you look at the languages listed so you keep the correct ones.
You could use a program like multiAVCHD, which basically uses tsmuxer for this, but has many options in a gui so you can reauthor the BD how you want it. I use it to remove unwanted video content, like trailers you're forced to watch.
BDInfo will identify the main movie (look for the longest runtime) and show you which playlist file to select. Go to the PLAYLIST folder and select it (probably the 00006.mpls file). Then everything pertaining to the main movie will load, i.e. the video, audio, subs, chapters.
Pull! Bang! Darn! -
That's how it works when you do movie-only with tsMuxer, it outputs a single *.m2ts file. No trailers or junk, and you can still deselect audio and sub tracks. If that doesn't serve your purpose, you need to use something like multiAVCHD or BDEdit then.
Pull! Bang! Darn! -
Choose demux in tsmuxer and deselect the video and pgs and just keep audio checked and demux after you load in the right playlist.
Correct me if I got it wrong but basically you can select audio files and subs that you don't want and select demux. That will get rid of these files but keep everything else untouched?Choose demux in tsmuxer and deselect the video and pgs and just keep audio checked and demux after you load in the right playlist.
Editing the original Blu-Ray Disc
By K4rm4d0n in forum Blu-ray RippingReplies: 4Last Post: 17th Jul 2011, 08:10 -
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 14:28 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 09:37 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 12:48
