I have several DV files (in AVI containers) captured from a VHS tape. Obviously these files are ginormous at 13GB per hour of video/audio. I want to encode them into h264 files in mp4 containers. I was wondering what bitrate I should select for the lowest file size while still maintaining very good quality. I would assume I could get away with a lower bitrate since VHS quality isn't that good to begin with, but am not sure and wonder since they are in DV format now, if the original format of VHS is irrelevant.
Use a bitrate calculator to find out.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Use constant quality encoding and you'll always get the right bitrate for the quality you ask for. VHS usually requires more bitrate than DVD because it is noisy and full of time base wiggle. Those two things eat up bitrate.
how to use ffdshow to encode captured video into h264 in directhow
By vrparekh@gmail.com in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Apr 2012, 11:08 -
ffmpeg: best possible quality for 720p h264(mp4), bitrate under 2 mbps
By lisx in forum Video ConversionReplies: 0Last Post: 1st Aug 2011, 14:56 -
Help on an H264 MP4 file...
By mjaeson in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2010, 10:05 -
I'm looking for a good MP4-2/H264 video encoder which should NOT be based o
By clipperyoungamerica in forum Video ConversionReplies: 7Last Post: 19th Mar 2010, 16:54 -
Trying to get a good digital capture of an old VHS tape
By StrobeLightEpileptic in forum RestorationReplies: 2Last Post: 21st Nov 2009, 21:16
