Hi,
I recorded some HDV footage on mini-dv tapes while using the Canon XH-A1s.
Sunday I will load the tapes in my new Imac, but to avoid having to rent the camera again, I will borrow a Canon XH-A1 from my friend to capture the video.
The 's' version is the new version of the xh-a1. We shot in 25 frames per second, on 1080P if i remember correctly.
Will we be able to playback the tapes and capture on the older version?
Thanks!
Details are important. I doubt the XH-A1 or XH-A1s shoots 1080p. Normal mode is 1440x1080i/25.
I'm not sure of the differences in the (s) model.
If you shot native 1440x1080i/25 (50 fields per second), the older camcorder should transfer fine. Even if the new model has a 1440x1080p/25 mode (progressive but more jerky) it should still transfer ok.
The (i) vs. (p) issue will affect editor project settings.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
the a1 only shoots 50/60i. the new a1s u.s. version shoots 60i/30p/24p all in a 60i stream. i would assume the pal a1s shoots 25p in a 50i stream. just capture as usual with the a1 and then import into the editor and change the file properties to 25p.
Canon HX-A1 verse HX-A1s and buying one
By SkeeterHarris in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Jun 2011, 23:04 -
Canon XH A1s (Grain Problems)
By mseidner24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 26th Feb 2011, 19:17 -
Canon Xh A1s Grain/Noise
By mseidner24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Feb 2010, 17:05 -
Any good guides on the Canon Xh A1s?
By Shamboola in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Apr 2009, 03:13 -
Canon XH-A1 or Canon XH-A1S?
By ProducerHarley in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2009, 23:34
