Hi, I got this video of a mate and it seems to be terribly out of sink, It's in VBR mp3 and video in xvid now i interleave it at the start but then 30 seconds later that scenes outta sink while the 1st is correct Is this just a bad vbr encode Or could be the framerate of the audio is different to the video ? , if i can't fix it simply ill just chop it in to parts and try to correct
nah it's totally f**ked just getting him too do another one
dw about it
What I would probably try is to drop it into VirtualDub (I prefer VD Mod for this) and save out the audio as a WAV with full processing. Leave VD running. Put that WAV into Audacity and stretch the audio time to fit the video time. (Change Tempo) You may have to adjust the pitch if it gets too low. Then add that repaired audio back with the video in VD as MP3 CBR, deleting the original there, and save the whole thing as a Direct stream copy.
I need to correct audio drift
By Djard in forum AudioReplies: 13Last Post: 30th Jan 2012, 18:32 -
Correct size Resolution for AVI
By Sliztzan in forum EditingReplies: 45Last Post: 25th May 2010, 11:01 -
Correct Out of Sync Audio in DV-AVI Type 2
By Atariwarrior in forum Video ConversionReplies: 15Last Post: 6th Mar 2009, 19:24 -
VHS to DV - Audio not correct
By jlorelle in forum Newbie / General discussionsReplies: 13Last Post: 15th Sep 2008, 11:36 -
how to correct the aspect ratio of AVI
By edong in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2008, 19:04
