Or at least, I hope it is. I am trying to open an avi file in Virtualdub to be cut, but keep coming up with an error message, namely that the decompressor for high-speed MPEG-4 V2 cannot be found. I read in the readme file that Vdub needs a decompressor for avi files, so is that the problem I am having? (I also ran the file through DivFix, since it was unfinished) Thnx to anyone who can help me out.
The AVI has been made with The "MS Mpeg 2 V2 codec", you need to install that codec before you can edit any of those type of movies.
Decompressor, compressor are terms used to describe the process of unpacking the movie or compressing the movie.
Think of it as a ZIP file, you need Winzip to decompress it ?
So you need the MS Codec installed to use V1,2 and 3
Search Grokster/Kazza for "Mpeg4 Codec.exe"
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 22:50 -
Simple DirectShow script for virtualdub
By streamking in forum Video ConversionReplies: 2Last Post: 28th Jan 2009, 15:43 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
another simple question about FCE and iDVD... =)
By ednarophati in forum MacReplies: 1Last Post: 31st Jul 2007, 11:15
