I recently encoded a DVD to XVID using XVID4PSP (I also use FairUse Wizard, these are my 2 favorites). I used QC 2.0 and the resulting files was 1.5GB and looked great! If I had done a 1 pass bitrate encode using "Ultra" preset and adjusted the bitrate until the estimated output file size was 1.5GB, would I have ended with the same outcome?
Close. If you go through the two videos frame by frame and compare them you'll see minor differences here and there. It's not worth worrying about. But I recommend you try it and see for yourself.
A few questions regarding quality, file size, etc...
By smackyourfupa in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 08:11 -
Does half d1 alter file size at all or is it just how the bitrate is used?
By yoda313 in forum Video ConversionReplies: 14Last Post: 17th Oct 2010, 20:28 -
Xvid bitrate and file size problem - Heeelp!
By Salinas in forum DVD RippingReplies: 0Last Post: 10th Mar 2010, 18:05 -
File Size & Video Bitrate Calculator
By wiseant in forum Video ConversionReplies: 3Last Post: 27th Nov 2009, 22:59 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 18:12
