Hi
I have a Samsung R130 DVD-R recorder and when I try to record onto Sony DVD-R disk it only records for about 4-5 seconds then ejects the disk. Any advice?
Do you get a copyright protection message? I know I get that when I try to do a dub of a commercial tape to dvdr. It will start recording for a few seconds than flash a copyright protection message and stop recording.
Also if you don't get a warning it could be a false copyright protection error - are you copying from a vhs source?
The next bit of advice is to try a different brand of discs. You could simply have a bad batch of discs.
Also its possible your dvd recorder may be dying.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
targa dvd/vhs recorder won't recognise dvd+rw discs.
By steve6 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 31st Jan 2011, 17:04 -
wont recognise camera connected
By sarah1 in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2010, 07:09 -
Tevion DVD Recorder DD1018 - not initialising disks - unknown
By mkam in forum Newbie / General discussionsReplies: 1Last Post: 15th Apr 2009, 23:10 -
MY PC WONT RECOGNISE PANASONIC NV - GS5 !! ANYONE HELP PLEASE ??
By GRENDLE in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 25th Feb 2008, 17:34 -
LG LH-D6246 region free some disks wont play
By sydneyozguy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Feb 2008, 21:25
