Hello,
I have edited videos in the past but this is my 1st time with Adobe Premiere 6.0. It is an older program but my friend has used with with good results.
When I uploaded my clips off my DV camcorder they play just fine on my computer. When I drop them into the editing timeline the clip doesn't play smoothly and jumps around. I have tried de-interlacing it but it did nothing. I am not sure what could cause this issue.
Here is an example.
http://www.youtube.com/watch?v=ise1zPnd_-Q
let me know what you think. Thanks!
Results 1 to 16 of 16
Looks like you got the field order wrong. The original DV would be bottom field first and you probably set it up in Premiere as top field first.
One thing I am sure of and that is the aspect ratio is off. You uploaded the 720x480 video. That's a 1.5:1 ratio where it should be 1.33:1. Either you should have resized it to 640x480 or similar before uploading, or you can add the tag:
yt:stretch=4:3
to have the YouTube player resize it.
http://www.google.com/support/youtube/bin/answer.py?hl=en&answer=146402
I just tried doing a little reading on field order. I am confused. What would I do to fix the field order?
DV is natively Lower Field First. When you start up Premiere, make sure your project preset is NTSC - DV (and, in most cases the audio should be 48kHz). In the descriptions, there should be something that says, "Rendering Options: Field Setting: Lower Field First."
I did some testing last night. It seems to be my clips off my camcorder that do this jumping. I tried other avi files and they ran smooth. I captured the footage off my camcorder with Windows Movie Maker in AVI mode. There must be something with that footage that Premiere doesn't like.
Any suggestions?? -
when you view it from the camcorder connected to tv is it "jumping" ?
what happens when you capture with windv ?
Are you saying it doesn't play now? on a media player?It seems to be my clips off my camcorder that do this jumping.
if it plays fine on the pc, except in premiere, it really sounds like reversed field order issue. Just change it in premiere
post a sample clip -
The video clips off the camera play fine until I drop them into the timeline to edit them on Premiere. No jumpyness when played with VLC as a unedited file.
Never tried winDV. Will it allow me to upload with a USB cable or does it need firewire?
Field order is set to lower field 1st. I checked last night.
Thank you for the help -
When you captured with Windows Movie Maker, weren't you going through firewire?
Please describe how you are interfacing between camcorder and computer. Your problem may be starting right at that point. -
I have never used a firewire and I have made about 7 other videos with various programs. I use a USB cable that was supplied with the camera.
Well then, we need to back up. You used the term "DV camcorder" in your opening post, which suggests miniDV. Are you recording to miniDV tape or some other medium? If you are not using firewire, you're probably not capturing DV-AVI files. (However, I suspect you may be doing a DV-AVI export with Windows Movie Maker, and thus getting the field mismatch.)
At this point, it would help to know the model of your camcorder and the type of media to which it records. -
dv-avi is supposed to be lower field first, but did you try upper or top field first in premiere ?
There you go. If you used firewire and a capture program like WinDV to transfer your minidv footage, you would get a straight, unconverted, bit-by-bit transfer of your DV footage. However, if you are first saving your video as a .wmv (which, I believe is Upper Field First) and thereafter exporting as DV-AVI (Lower Field First), then you are not only getting field mismatches, but unnecessarily re-encoding and degrading your footage.
Firewire cards are very cheap, and a capture utility like WinDV is free. I suggest you change your methods. -
http://www.outletpc.com/c5539.html
Do all firewire cards work with all computers? I have a Dell Dimension 3000 from 2005 running windows XP. Upgrading my RAM to 1gb soon.
Sony HDR-SR7 recorded video jumping around...
By MikeZZZZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 54Last Post: 11th Feb 2017, 04:23 -
How To Fix A Video So There's No Annoying flickering Line Above Video Field
By adidasos in forum EditingReplies: 2Last Post: 27th Jun 2011, 05:55 -
jumping video
By natty in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 12:27 -
Jumping, Stuttering Video
By Smack2k in forum Video Streaming DownloadingReplies: 7Last Post: 6th Jul 2009, 20:36 -
video flickering
By LonghornIII in forum Video ConversionReplies: 1Last Post: 17th May 2009, 20:58
