Hi, I wanted to move a project from my stationary pc to the laptop. So I consolidated the media onto a portable harddisked and copied it to a local harddrive on the laptop. And I moved the project and user files to the new system. The systems are identical versions, I just move the dongle to the system I use.
I relink the files and everything seems to be all right when I look at the master clips. But the timeline is completely wrong. If I look at the previous system the sequence should start with NJ Bin.09 but it starts with NJ Bin.13.Sub.02. I have only one sequence in the project. Now all the clips on the timeline is mixed.
How can I save my project?![]()
Results 1 to 1 of 1
"My opinions may have changed but not the fact that I am right!"
All in one converter for x64 systems?
By davidsl_128 in forum Video ConversionReplies: 4Last Post: 7th Feb 2011, 15:29 -
dual-boot systems
By joecass in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2011, 20:01 -
Moving between Avid systems
By Jorx in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2010, 14:36 -
64 bit op systems
By dblake2 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2008, 16:44 -
all in one home theater systems
By CODEWERKX in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2007, 11:09
