Hi there,
I'm editing a video with premiere and found this issue while exporting the media: in a previous exported file everything looked fine, no problems at all. Then I *** messed around with the frame rate ***
Problem is, the video is slightly out of focus. This only happens during motion
*** SEE WHY IN THE END OF THE THREAD ***
Ok I fixed it by just cutting the clip in two pieces, then I applied the effect on the initial part only.
if anyone still wants to explain me why that happened, I'm here listening -
Oops the problem it's still there. In the preview it doesn't appear anymore, but once i finished encoding I loaded the avs of the avi file and looked at it frame by frame: it's still there!!!
What did I do? I must have messed up with something... -
I suspect you have interlaced video and are handling it as progressive. Post some sample clips?
Ok, I messed it up.
The video as Adobe recognizes it is progressive 1280x544 23,975 pixel ar (0,755)
When I imported it i changed the pixels aspect ratio to 1.0, I put in the right resolution (544p), i made sure it was progressive BUT...
I didn't pay attention to the frame rate. Adobe recognized it as 23,975 fps and since I didn't change it the slight difference between the sequence format and the video's one caused the problem.
I changed it to 23,976, Adobe would yet (for some reason) set it as 23,98, nevertheless it works perfectly!
I changed the thread title, maybe this could be useful in the future for someone else as noob as me.
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 20:39 -
Problem - Audio Slows Down when importing video to Premiere
By w.campinas in forum EditingReplies: 7Last Post: 7th Jan 2011, 13:29 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 01:56 -
After Effects to Premiere... importing problems?
By Saibot in forum EditingReplies: 1Last Post: 21st Feb 2009, 22:48 -
Problems with importing converted vob into Premiere Pro
By fishytastic in forum EditingReplies: 6Last Post: 16th Oct 2008, 14:18
