    Nov 2010
    I am looking for any help on how to add an mp3 audio file onto a video file. The video format is in mp4. I can cut the mp3 to the length of the video clip but how can I sync that audio with that clip the easiest way. Any advice here please? Also what's the best format for a video which gives high quality picture and sound? Thanks.
    Apr 2004
    Miskatonic U
    When you say sync do you mean before the cutting, or do you mean just muxing the audio and video together.
    If it is the former, try Reaper for a free solution that lets you see the video while working on the audio.
    If you are just muxing, try Yamp.
    Read my blog here.
    Nov 2010
    I have a cut Mp3 clip which needs to be inserted in the video at the right point... so yes I would need to watch the video too. Will try reaper. I hope I can do it on the trial version. Thanks again.
  4. The trial version is unrestricted.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can't just insert a piece of audio into a video container at an arbitrary point. It has to be a complete audio track with a matching length to the video. So you will either have to mix it into the existing original audio, or create a new track with silence up to the point where you audio starts, and from the end of your audio to the end of the clip.
    Read my blog here.
