  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I keep getting this error?
    I'm using port 587 like comcast says to
    and outgoing smtp.comcast.net
    What We Do In Life, Echoes In Eternity....
  2. smtp.comcast.net is only for sending mail with a comcast.net account name. to retrieve mail from a comcast account use mail.comcast.net
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
ID:	4062Click image for larger version
    mail.comcast.net is my incoming server which works fine
    I see the confusion, in my thread title I put can't receive emails, I meant to put can't send them. Sorry for that mix up.
    Feb 2004
    Australia
    Change server time out to 1 minute and try again.
    Then
    You may need to unhide hidden folders option in windows exploer > tools > folder option > view tab ... hidden files and folders to "show" ... apply ... ok
    Next
    1: Close windows mail
    2: You need to locate the directory where windows mail stores it's data for inbox, outbox, ect
    Normally this is : C:\Users\Your windows user logon name\AppData\Local\Microsoft\Windows Live Mail
    A Folder with the name of comcast in your case will include such directories as inbox, deleted, sent, ect
    3: When found, copy all these folders from here to a safe location elsewhere
    4: Once a safe copy has been done ... delete "sent" folder.
    5: Then back to windows live mail directory ... and delete "Outbox" folder
    5: Try windows mail once again
    Windows mail will recreate the missing directories.
  5. my reply in a screenshot as the forum won't allow it to post for some reason.
  6. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    If tried everything comcast and microsoft have posted on the net for this issue. I have all the sam boxes checked, numbers used, but still not able to send.
    My solution Mozilla Thunderbird, works like a charm, just need to get used it, but works just fine, and very easy to setup account.
