Please, I need a quick education on the topic of using/choosing drop frame versus non-drop frame on a Premiere Pro HDV project especially as it’s related to or may directly impact on rendering/compression quality or may even cause compatibility issues with the source footage.
Bottom line: Is there any visible or discernable difference seen on the resulting video after being rendered/compressed when played back?
What should I know and keep in mind in regards to this aspect of video processing going forward?
Thank you.
Drop frame has nothing to do with picture quality. Drop frame is used to time TV programs to take into account the 59.97 fps NTSC rate vs. 60 minute real world clock.
See http://en.wikipedia.org/wiki/SMPTE_time_codeRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
So in essence, does it make any difference whether I select drop frame or non drop frame in:
A) Premiere's master project settings and/or:
B) Premieres export the timeline to Adobe Media encoder where there is a setting for that also in AME.
EdDv, my memory fails me.... aren't you a Vegas guy? -
Which is preferable to drop 2 frames every so often or keep all of them?
HDV tape timecode can be either drop frame or non drop frame. it just depends on the camera and the setting. you need to find out which it is on your stuff.
Depends if you are making a program intended for broadcast (e.g. with commercial breaks, etc.). The TV station or syndicator will have tight specifications on time code and segement lengths.
If you are making a DVD, non-drop frame is fine. It gives a continous time code count. Just be aware it will be off by about 4 seconds every hour vs. a stop watch.
I use Vegas, FCP or Premiere depending on the project needs. Most routine editing is done in Vegas.Recommends: Kiva.org - Loans that change lives.
jvc gy-hm 700 drop frame
By seistro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 23rd Sep 2012, 13:31 -
Dazzle 720x 480 Frame Drop
By genericman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Mar 2011, 11:37 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 05:22 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 19th Oct 2007, 12:29
