I've been using Adobe Media Encoder CS4 to transcode movies (MOV) prior to DVD authoring in Encore CS4. This is because to transcode after importing the originals into Encore takes literally days. This workflow allows me to split the job to suit myself.
But I just can't find a combination of settings in Media Encoder which doesn't result in a loss of audio in Encore.
This is the one set of Encoder settings I thought would work for sure, but doesn't:
Format: MPEG2-DVD
TV: PAL Widescreen
Field order: Lower
VBR, 2 Pass
Min BR=3, Target BR=3.5, Max BR=4 Mb/s
Audio: PCM 16 bit, 48 kHz
Multiplexer: DVD, VBR
As I said, I've tried different settings and combinations of format, audio, multiplexer, but none works in Encore, i.e. audio plays (video is fine).
Further, when I build the DVD even without audio, the resulting VOBs won't play at all - no video or audio stream!
Can anyone please help me here?
thanks
James
Does it export video & audio (.m2v and .wav) from AME successfully?
Can you see the .wav in Encore before building the disc ? -
.m2v and .wav are exported separately if I set the Multiplexer to None.
Blu-ray in Encore CS4
By helionfilm in forum Authoring (Blu-ray)Replies: 5Last Post: 31st Aug 2014, 18:54 -
Subtitling using Encore CS4
By mmsanthu in forum Authoring (DVD)Replies: 4Last Post: 25th Nov 2011, 09:51 -
Getting WMV into Encore CS4 for a DVD
By CreativePixel in forum Authoring (DVD)Replies: 5Last Post: 8th Oct 2010, 08:46 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
h264 codec in Encore CS4
By koberulz in forum Authoring (Blu-ray)Replies: 22Last Post: 21st Oct 2009, 10:54
