I have an XVid AVI that I want to cut out one short scene..
I cut the scene, set the video and audio to 'copy' (so it doesn't re-encode), and save the new video..
But- I can't play the new video.. I can hear the audio, but not see the video..
I CAN play the original, no problem..
Results 1 to 9 of 9
did you cut on keyframes? (if not, did it ask you to smart render?)
did you use format=> avi ?
did you give name + extension (e.g. "myvideo.avi") ? -
I'm not sure if I cut out keyframes or not.. when I saved the video, it DID ask if I wanted to smart render (and I clicked 'yes')..
My output format is AVI (no specific configuring, Normal Muxing, etc)
I add the extention on render (test.avi) as I saw it didn't add it automatically..
Very weird problem, I hope it can be solved.. -
Mediainfo doesn't show any errors:
Container and general information
AVI: 694 MiB, 1h 20m
1 video stream: MPEG-4 Visual (XviD)
1 audio stream: MPEG Audio (MP3)
First video stream
1 077 Kbps, 640*336 (1,905), at 25.000 fps, MPEG-4 Visual (XviD) (Simple@L3)(BVOP)
First audio stream
117 Kbps, 48.0 KHz, 16 bits, 2 channels, MPEG Audio (MP3) (Version 1)(Layer 3)(Joint stereo / MS Stereo)
It is the latest version of AVIDemux (I just downloaded it)
I'm just trying to play it in Windows Media Player (the original does play)..
I guess I can try to change the Video settings from 'Copy' to MPEG-4 ASP (XviD), although I think that re-encodes, right? I'm trying to avoid that..
This should be easy, I'm literally just cutting out one shot.. -
*** Now that you have read me, do some other things. ***
why does Avidemux play back files faster or slower
By mukluk909 in forum EditingReplies: 1Last Post: 2nd May 2011, 13:26 -
Avidemux: character voices from a DVD only play in a channel
By Anubis5 in forum DVD RippingReplies: 1Last Post: 19th May 2009, 09:57 -
Question why suddenly cannot play certain avis
By jimdagys in forum Newbie / General discussionsReplies: 5Last Post: 4th Nov 2008, 18:17 -
Can you play AVIs from a DVD?
By benvid in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2008, 17:18 -
Can't get MP4 Player to play AVIs
By Bullworth in forum DVD RippingReplies: 4Last Post: 12th Jun 2008, 13:21
