Hi all !
I'm not sure I'm in the good forum for this, but I reckon it can't be entirely the wrong place.
Also, I believe I saw the question asked once, but the original poster never got any real answer to this.
So here it goes : in MediaInfo, what do they mean when they evaluate the Bit rate of a video file (assuming VBR, since CBR must give the obvious answer) ? Do they mean to show the average bitrate ? Or the maximum bitrate used ? I read that softwares will alternate between the two, so I wonder which one MediaInfo uses, unless it means something else entirely ?
Thanks in advance !![]()
It isn't accurate, because it reads header information (can be wrong). For some types of files it is the bitrate entered when encoding, for others, it's the maximum bitrate entered (not necessarily achieved), for others it's the average bitrate. Eitherway it can be incorrect
You need to parse the video if you want accurate bitrate information e.g. bitrate viewer , elecard streameye -
Ok so it depends as much on the type of file as on the software itself.
Nice ! Thanks ! Now at least I can put my efforts in finding an alternate solution !
I'll see those softwares you mentionned, I think I'll need em !
What Version Of MediaInfo To Use?
By MOVIEGEEK in forum Software PlayingReplies: 58Last Post: 1st Jun 2015, 09:43 -
Why doesn't handbrake re-encode show video bitrate in MediaInfo?
By KushSmoka420 in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 16:55 -
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 23:22 -
TC in MediaInfo?
By dnc in forum Newbie / General discussionsReplies: 4Last Post: 8th Feb 2010, 11:53 -
GSpot and Mediainfo Help
By swampwizard in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2008, 09:03
