I been using DVD videosoft i have tried FLV -high Definition,AVI -high Definition and MP4 -high definition,but i have noticed there is noise, blocking on the picture some times and is not so smooth frame loss..that was not on the original video on YOU TUBE..is there a better down load software out there are all they the same...i want to get the same quality,the best if possible...
thank you Everyone..
Results 1 to 9 of 9
If the video was not uploaded in "good quality" then you won't get good quality....certainly not HD quality. If this software you are using to download the videos offers an "get the HD version" option on every video that you see on YouTube then it is lying to you.
firefox with the download helper will let you choose which version to download. the files are the same as on the tube.
hech54 is right. Not all youtube videos are in high definition and not all are in great quality. You should have a downloader that lets you pick the top quality option. Personally I use antbar to download youtube videos. It does offer the option to download the highest quality file - it is decided by file size it doesn't say high def but the largest file is the "best quality".
The downloaded file you get is what you see on youtube - unless you downloaded the lowest quality file and not the top quality file. But you won't get better quality than what was uploaded. That is not possible. You are stuck with the quality that is on youtube unless you can track down the original source somehow.
You can convert the files to dvd or another format for another player but remember there will be some quality loss but it should be watchable - just don't expect it to look like a professional commercial released dvd or bluray.
Streamtransport is another option for downloading from youtube - it can also download from rtmpe protected sites fyi.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
only some videos i have coped on YOU TUBE are high definition..i am only use the high definition option to down load to keep the same quality as possible..they say also.The downloaded file you get is what you see on youtube..but i have notice on fast,colour seens there is some small blocking noise...so it is not...100% the same
StreamTransport as yoda313 suggested. Download Helper has a lower success rate than StreamTransport, but it is somewhat easier to use.
You were already given some good options. Me, I use VideoCacheView and play the highest quality version listed.
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 06:47 -
Adding transitions to videos with free software
By Cyber Akuma in forum EditingReplies: 61Last Post: 8th Dec 2010, 11:36 -
You Tube videos
By joecass in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2009, 16:48 -
Can't view embeded You Tube Videos
By Ensign in forum Video Streaming DownloadingReplies: 11Last Post: 27th Mar 2009, 12:28 -
Help dowloading and conveting you tube videos.
By twells22 in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2007, 13:13
