    Dec 2009
    I"m getting an error when processing a Blu-ray disc through RipBot. Here's the error:
    I've no idea what it means. Can anyone explain it? Thanks for any help.
  2. I'm getting a similar error:
    eac3to v3.24
    command line: "C:\Program Files (x86)\RipBot\Tools\eac3to\eac3to.exe" "K:\" 1) 2: "F:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "F:\temp\RipBot264temp\job1\audio_English.dtsma.w6 4" -down16 1: "F:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="F:\temp\RipBot264temp\job1\demuxlog.txt"
    M2TS, 1 video track, 2 audio tracks, 3 subtitle tracks, 3:21:01, 24p /1.001
    1: Chapters, 60 chapters
    2: VC-1, 1080p24 /1.001 (16:9)
    3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz
    (core: DTS-ES, 5.1 channels, 24 bits, 1509kbps, 48kHz)
    4: AC3 EX, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
    5: Subtitle (PGS), English
    6: Subtitle (PGS), Spanish
    7: Subtitle (PGS), Spanish
    Creating file "F:\temp\RipBot264temp\job1\chapters.txt"...
    [a03] Extracting audio track number 3...
    [v02] Extracting video track number 2...
    [a03] Decoding with ArcSoft DTS Decoder...
    [a03] Reducing depth from 24 to 16 bits...
    [a03] Writing W64...
    Trying to convert Lord Of The Rings Return Of The King to MP4 so I can watch it on my XBOX 360...I've done this with the other blu rays in my collection (>20 so far) with no problems. The disc plays fine, by the way, and AnyDVDHD can rip it to an ISO with no problem, so I don't believe the disc is bad...
    USA
    What I've had to do with a few BDs is to run the ripped file through tsMuxeR and just select only the video and audio tracks you want, mux them, then run that through RipBot. But I converted all three LOTR BDs to 8GB MKVs with AC3 with no problems using just RipBot.
