Hi There,
I'm new here & my name is Johnathan.
Not sure where I should post this question & will appreciate all the help I can get.
I've been using the Canopus DV Storm 2 since the mid 90s.
It has worked extremely well all these years except that it gets tricky each time
I upgrade the system or do a fresh OS install.
It will take sometime to figure out how to get the system to recognise the hardware
& have the drivers properly loaded & accepted by the system but once that is achieved,
it will be plain sailing till the next system upgrade or OS install.
I've now upgraded my system & switched OS from XP Pro to Windows 7 64 bit.
I'm having trouble getting the drivers to be accepted by the system & am now unable to
use the DV Storm 2. I'm crossing my fingers that some of the good people here are DV Storm 2 users & may have
come across the same problems I'm having but have the knowledge to overcome this problem.
Will appreciate any help I can get coming my way.
The following are my computer details:-
OS Windows 7 64 bit
CPU Intel Core™ i7-870 2.93GHz
Motherboard - Socket 1156 Gigabyte GA-P55A-UD3P
Graphics - Gigabyte GV-N460OC-1GI GTX460 1GB
Ram OCZ 2GB X 4
C Drive WD 500 GB Black edition partitioned with D
External WD 1 TB
Thank you all in advance.
Best regards,
Johnathan.
Last edited by Johnathan David; 2nd Nov 2010 at 23:40. Reason: left out motherboard details
Check the Canopus support site (now Grass Valley) to see if they have drivers for Win 7 64 bit.
Good luck with that. Don't toss your XP machine.
Or consider dual boot with XP/Win7.Last edited by edDV; 3rd Nov 2010 at 01:48.
http://www.kiva.org/about -
Hi edDV,
I did download whatever drivers there was available at the Grass Valley site but could not get the card to work.
Guess I have to keep searching.
Thanks for your input.
Regards,
Johnathan. -
Converting video for Blackberry Storm
By WuTangDvD in forum Portable VideoReplies: 4Last Post: 7th Mar 2009, 15:51 -
Storm, Pinnacle? or..?
By oztek in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jan 2008, 04:15 -
BBC reports Storm Worm attack on Blogger
By ahhaa in forum ComputerReplies: 0Last Post: 31st Aug 2007, 09:16 -
Yoda caught in compromising video with Storm Trooper
By AlecWest in forum Off topicReplies: 4Last Post: 25th May 2007, 01:04
