Hello,
I am looking for a highly rated wireless N usb adapter. There are so many to choose from. I won't be doing any kind of video transfer just need it for good range Internet connection. Do you have any recommendations? The pc will be about 50 feet from the router on the same floor between two walls. Here are a couple I am looking at. Want them to last. What is the difference between 150Mbps & 300Mbps? Will I see a difference in Internet speed with 300Mbps? What does Mbps stand for?
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166048&cm_re=Wireless_N_USB_A...-048-_-Product
http://www.amazon.com/NETGEAR-WN111-Wireless-N-300-Adapter/dp/B000W8UIZW/ref=sr_1_11?s...740182&sr=1-11
http://www.amazon.com/Hawking-HWUN3-Wireless-N-Upgradeable-Antennas/dp/B001O5BF0Y/ref=...740730&sr=1-22
first off i wouldnt pay that much over $25 for one...friend of mine has a cheapy "airlink" brand($10) its been runnin for almost 4 years with no problems...here are some within the $25 and below price range...sort by best reviewed or brand
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100010074%204093%206000142...name=USB%202.0
those numbers u were referring to are just transfer speeds...you'll nvr see em unless u have a super high speed fiber connection and are close to the router/wireless your getting the connection from -
If you are on Win7, verify that the adapters work under Win7.
The ones from Amazon don't say that they are Win7 compatable.
When Win7 first came out, my 4 USB adapters they did not work on Win7.
I didn't believe it, and finally Microsoft told me over the phone that it was so.
Need help in order to purchase Wireless USB 2.0 Adapter
By Neil_2004 in forum Video Streaming DownloadingReplies: 2Last Post: 10th May 2010, 15:21 -
Wireless usb adapter on WD TV
By kyrcy in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Apr 2010, 18:50 -
Wireless Adapter
By Sakuya in forum ComputerReplies: 13Last Post: 21st Dec 2009, 23:40 -
Sprint/Novatel U727 USB Wireless Internet Adapter
By ahhaa in forum ComputerReplies: 2Last Post: 18th Dec 2008, 15:49 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
