Hello together =))
Could someone please help me with my problem? I don't get it to work...
I have a Darwin Stream Server running on Suse 11.3. The sample videos are working perfect, but i don't get it to work to convert my own video files to stream them over rstp.
I'm working now on this for around 3 weeks =(
I know already, that i have to use the mp4 package for the files.
And i know that i can use h263 or h264 for the video.
And i have read that i have to add a "hint" for the video in the mp4 file, that i can stream it with Darwin Stream Server.
But i can't watch my files (converted with ffmpeg to mp4 with h263 video, no audio, and added a hint with mp4box) over rtsp...
What settings in ffmpeg and mp4box do i have to use to convert the movie to get it worked to stream it with darwin stream server???
I would not have a problem to use another program, the only thing is, that the converting program(s) need to work with Commandline (like cmd), and it doesn't matter if i would need Windows or Suse as opperating System (but i would like Windows more).
And one thing anymore: (I don't know if it is important). The converted movie file have to be the same file, like the files on http://m.youtube.com - because i need to stream the movies for mobile phones.
Thank you already very very much for your help,
Greathings from Germany, Sunnyboy88
PS: Sorry if my english is not the best, i gave my best... =)
	What ffmpeg settings have you tried? Just default or?
 I use vlc with darwin and it works fine, see example:
 http://wiki.videolan.org/Documentation:Streaming_HowTo/Streaming_a_live_video_feed_to_..._Mobile_Phones
	Hello Baldrick
 thank you for your replay =))
 I didn't want to stream a live video (but its good to know that this is working with vlc, too =) ). I only wanted to stream a video file, like the sample videos of Darwin Stream Server.
 I used the following settings with ffmpeg:ffmpeg.exe -i movie.avi -f 3gp -vcodec h263 -s 176x144 -an -y output.3gp And the beginning movie was flash movie so i converted it into a avi format with the ffmpeg GUI S.U.P.E.R
 And after that, i only add a hint with mp4box to the output.3gp file.
 (I'm sorry, but i think i don't have a too big known about movies and file formats)
 Greethings from Germany,
 Sunnyboy88
	Hey cool =)) This program is really great =)))
 Ok here is now the text info about the sample file from Darwin:
 Allgemein
 Complete name : S:\sample_50kbit.3gp
 Format : MPEG-4
 Format profile : 3GPP Media Release 5
 Codec ID : 3gp5
 File size : 590 KiB
 Duration : 1min 10s
 Overall bit rate : 69,0 Kbps
 Encoded date : UTC 2005-03-01 00:59:25
 Tagged date : UTC 2005-03-01 00:59:26
 Video
 Format : MPEG-4 Visual
 Format profile : Simple@L0
 Format settings, BVOP : Ja
 Format settings, QPel : Nein
 Format settings, GMC : Keine warppoints
 Format settings, Matrix : Default (H.263)
 Codec ID : 20
 Duration : 1min 10s
 Bit rate mode : konstant
 Bit rate : 40,0 Kbps
 Width : 176 Pixel
 Height : 144 Pixel
 Display aspect ratio : 1,222
 Frame rate mode : konstant
 Frame rate : 15,000 FPS
 Color space : YUV
 Bit depth : 8 bits
 Scan type : progressiv
 Bits/(Pixel*Frame) : 0.105
 Stream size : 354 KiB (60%)
 Language : Englisch
 Audio
 Format : AMR
 Format/Info : Adaptive Multi-Rate
 Format profile : Narrow band
 Codec ID : samr
 Duration : 1min 9s
 Bit rate : 8 000 bps
 Channel(s) : 1 Kanal
 Sampling rate : 8 000 Hz
 Bit depth : 13 bits
 Stream size : 68,3 KiB (12%)
 Writing library : Apple Revision 1
 Language : Englisch
  Streaming considerations - RTMP vs RTSP vs HLS vs MMS vs ?By rezilient in forum Video Streaming DownloadingReplies: 3Last Post: 14th Apr 2016, 01:25
  Recording Stream on local computer : Streaming Server Wowza Media Server 2By iLove in forum Video Streaming DownloadingReplies: 2Last Post: 19th Apr 2012, 17:25
  Need Windows streaming encoder for Quicktime/Darwin streaming server?By The village idiot in forum Video Streaming DownloadingReplies: 0Last Post: 10th Feb 2012, 15:50
  Difference between VLC and Darwin Streaming ServerBy Guumper in forum Video Streaming DownloadingReplies: 2Last Post: 27th Aug 2009, 13:43
  VLC as a rtsp serverBy dafodill in forum Software PlayingReplies: 1Last Post: 24th Apr 2009, 04:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
